[mapguide-trac] #1026: Prevent session timeout,
and give better error messages (RFC 66)
trac_mapguide at osgeo.org
Thu Jul 23 03:38:49 EDT 2009
#1026: Prevent session timeout, and give better error messages (RFC 66)
Reporter: CXYS | Owner: Tom Fukushima
Type: defect | Status: reopened
Priority: medium | Milestone: 2.2
Component: General | Version: 2.0.2
Severity: major | Resolution:
Keywords: | External_id:
Comment (by christinebao):
Hi Kenneth,
I considered to share the same functions between templates, in that way
we don't duplicate code. However the problem is I can't find a suitable
place to put these functions. It seems there are js files included by the
templates and shared, such as browserdetect.js, but none of them are
suitable for encodeComponent() and ParseLocalizedFloat(). What's your
suggestion?
I'll add comments for the ping server interval. Thanks for your
suggestion.
Thanks & regards,
Christine
Replying to [comment:14 ksgeograf]:
> In (4) and (5), I think you can use the same function/variable name, but
you are replicating the code. My comment was that this is hard to
maintain, and -in a perfect world-, the two templ files would share the
function, so it only has be maintained in one place.
> For (6), I read num / 5 * 1000 as: num / 5 seconds, which is not what is
meant. I would suggest a comment like:[[BR]]
> //Ping server 5 times each period. Timeout is returned in seconds.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1026#comment:15>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
