[mapguide-trac] #1036: Oracle to Sdf join does not work
trac_mapguide at osgeo.org
Thu Jul 23 16:35:45 EDT 2009
Reporter: bscott | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 2.1
Component: Server | Version: 2.0.2
Severity: trivial | Resolution:
Keywords: | External_id:
Comment (by brucedechant):
I tested Oracle (Primary) joined to SDF (secondary) using a single join
key that was a string property and it worked. This was a Left-Outer 1-Many
join.
Can you clarify if you are using a composite key for the join?
What is the data type of the join property?
Also, what type of join are you doing - Inner/Outer, 1-1, 1-Many?
A specific test case that shows this failing would be helpful as the test
cases I have are passing.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1036#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
