[mapguide-trac] #1015: 2.1 beta default install results in errors -
missing dlls
trac_mapguide at osgeo.org
Fri Jun 12 09:30:53 EDT 2009
#1015: 2.1 beta default install results in errors - missing dlls
Reporter: andrewd | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 2.1
Component: General | Version: 2.1.0
Severity: critical | Keywords:
External_id: |
This is a minor bug, but if it's not fixed it will result in most users
getting an error, right out of the box.
Using a default install, you get an error when trying to edit layers - the
error says it's missing libpq.dll and oci.dll. The fix for this is to
simply comment out the PostGIS and KingOracle FDOs in providers.xml...but
would it not make more sense to comment those out by default, since most
people will be getting these errors every time they try to edit a layer?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1015>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
