[mapguide-trac] #1015: 2.1 beta default install results in
errors - missing dlls
trac_mapguide at osgeo.org
Mon Jun 15 11:44:16 EDT 2009
#1015: 2.1 beta default install results in errors - missing dlls
Reporter: andrewd | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 2.1
Component: General | Version: 2.1.0
Severity: critical | Resolution:
Keywords: | External_id:
Comment (by jbirch):
Nope, not easy at all because the provider sections in config.xml are not
uniquely identified (so can't be easily added/removed), and because
actually testing the dependencies would require a custom action. Feel
free to apply some resources to the problem if you can think of a way of
doing it :)
The only interim workaround that I can think of is to comment out the
providers with external dependencies, or possibly remove them to a second
file (providers_disabled.xml or something like that) so users can manually
enable these when they have the dependencies?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1015#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
