[mapguide-trac] #871: Installer: build script does not use value of
PARAFFIN variable
trac_mapguide at osgeo.org
Mon Mar 2 19:02:33 EST 2009
#871: Installer: build script does not use value of PARAFFIN variable
Reporter: jbirch | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: Installer | Version:
Severity: trivial | Keywords:
External_id: |
It allows you to set it, but then uses %CD% in the following PATH line
instead of the value of PARAFFIN.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/871>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
