[mapguide-trac] #894: Installer: move commonly set variables out of
	build.bat into setenvironment.bat
    trac_mapguide at osgeo.org
    Wed Mar 11 19:35:30 EDT 2009
#894: Installer: move commonly set variables out of build.bat into
setenvironment.bat
   Reporter:  jbirch       |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Installer    |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 Currently, I have to modify some values (locations of paraffin, ant, java,
 etc) in the !MapGuide and Installer build.bat scripts every time something
 changes in them.   It would be handy if:
  * the build.bat scripts tested for existing environment variables and
 uses them if they are set externally
  * a "template" setenvironment.bat script could be checked into the
 repository
 Under normal conditions, the developer would copy this setenvironment
 script into an uncontrolled directory, and keep local modifications there
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/894>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
