[mapguide-trac] #913: The coordinate system initialization
failed. - Could not initialize the geodetic transformation.
trac_mapguide at osgeo.org
Wed Mar 25 20:00:20 EDT 2009
#913: The coordinate system initialization failed. - Could not initialize the
Reporter: zspitzer | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 2.1
Component: Mapping Service | Version:
Severity: blocker | Resolution:
Keywords: | External_id:
Comment (by jbirch):
And I get the same error for another map in same/similar CS:
PROJCS["UTM83-10",GEOGCS["LL83",DATUM["NAD83",SPHEROID
["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT
["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER
["false_easting",500000.000],PARAMETER["false_northing",0.000],PARAMETER
["central_meridian",-123.00000000000000],PARAMETER["scale_factor",0.9996],PARAMETER
["latitude_of_origin",0.000],UNIT["Meter",1.00000000000000]]
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/913#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
