[mapguide-trac] #929: Installer: Should be setting php's session.save_path
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 26 06:09:30 EDT 2009
   Reporter:  jbirch     |       Owner:
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:  2.1
  Component:  Installer  |     Version:  2.1.0
   Severity:  minor      |    Keywords:
External_id:             |
 Fusion and I believe the !MapAdmin use PHP sessions, and if this parameter
 is not set in php.ini user can face inexplicable errors (because PHP
 errors are not displayed).
 The current method of grabbing the TEMP env var returns the current user's
 profile TEMP directory, which is undesirable.
 I believe that the best workaround for this would be to create a Temp
 directory at the same level as www, php, apache2, etc.  This could also be
 used for the !TempDir seting in webconfig.ini.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/929>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
