[mapguide-trac] #942: Maestro: Support for LayerDefinition-1.3.0
MapGuide Open Source trac_mapguide at osgeo.org
Tue Mar 31 04:10:30 EDT 2009
   Reporter:  ksgeograf  |       Owner:  ksgeograf
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:
  Component:  Maestro    |     Version:
   Severity:  trivial    |    Keywords:
External_id:             |
 When MapGuide OS 2.1 is released, it will support some new options on the
 layer definition.
 As Maestro is MapGuide version agnostic, it should be able to handle the
 new version.
 To correctly support changing versions, any version after 1.1 has an
 Extension element to hold unsupported elements. When changing versions,
 extra properties should be read and written using the extensions.
 This ticket has two stages:
 1. Implement a version changer function for MaestroAPI.
 2. Add a version combobox on the Layer editor in Maestro.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/942>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
