[mapguide-trac] #985: SymbolType.InsertionPointY LDF schema element
is wrong type
trac_mapguide at osgeo.org
Wed May 13 16:37:59 EDT 2009
#985: SymbolType.InsertionPointY LDF schema element is wrong type
Reporter: waltweltonlair | Owner:
Type: defect | Status: new
Priority: low | Milestone: 2.2
Component: General | Version: 2.1.0
Severity: trivial | Keywords: xsd
External_id: |
The !LayerDefinition schema has a !SymbolType element with InsertionPointX
and InsertionPointY child elements. InsertionPointX is defined as a
string, but InsertionPointY is incorrectly defined as a double. It needs
to also be a string so that it can support expressions. Note that the
data model (!MdfModel) and stylization already treat both as strings that
This change will most likely require that we bump the schema version, but
it's not worth doing it just to fix this one issue. The bug has existed
since the beginning of MGOS, and no one seems to have ever tried saving a
layer definition that uses an expression for InsertionPointY (which is why
I've set the ticket priority to low). At some point we'll be updating the
schema with new functionality, and at that point we can roll in this fix
as well.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/985>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
