[mapguide-trac] #993: After commiting resources through Mapguide API the reloaded map AJAX viewer produces HTML error which breaks map
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 20 11:41:40 EDT 2009
   Reporter:  cagray       |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  AJAX Viewer  |     Version:  2.1.0
   Severity:  major        |    Keywords:
External_id:               |
 After editing or creating a layer's resource xml and submitting it to the
 MapGuide repository (session or library) using the dotNet MapGuide API,
 the AJAX viewer produces HTML which seems to have an unmatched META tag if
 you reload (not refresh) the map or the iframe containing the map. This
 breaks the AJAX viewer. The error is:
 Error: mismatched tag. Expected: </meta>.
 Source File: http://dias/mapguide/mapagent/mapagent.fcgi
 Line: 6, Column: 3
 Source Code:
 </head>
 (This error is shown in Firefox's error console). This error means that
 once you zoom in or out the map disappears. As soon as you click on the
 'Initial Map View' button the map/HTML no longer has this error and
 functions correctly.
 This did not occur in version 2.0. It may be worth noting that this error
 occurred many more times in initial 2.1 versions but latest install (0.7)
 it occurs less but still a significant amount to make the AJAX  unusable
 when updating/adding resources via the dotNET API which requires a map
 reload.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/993>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
