[mapguide-trac] #982: Installer dosen't create virtual dir
mapviewnet
trac_mapguide at osgeo.org
Fri May 22 01:31:32 EDT 2009
#982: Installer dosen't create virtual dir mapviewnet
Reporter: nimcnaan | Owner: jbirch
Type: defect | Status: closed
Priority: medium | Milestone: 2.1
Component: Installer | Version: 2.1.0
Severity: major | Resolution: wontfix
Keywords: | External_id:
Changes (by jbirch):
* status: assigned => closed
* resolution: => wontfix
Comment:
I consider this a bug in the Web Tier tests (and have submitted a ticket).
They should not be referencing files directly from the individual viewer
folders, and the server helper script with hard-coded admin password
should definitely not be in there. If users really need access to these
(incredible insecure) tests under .Net, they can create the vdir
themselves.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/982#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
