[mapguide-trac] #333: Fusion: Select polygon tool/widget does
not tell you how to abort/finish the process
trac_mapguide at osgeo.org
Fri May 22 03:15:32 EDT 2009
#333: Fusion: Select polygon tool/widget does not tell you how to abort/finish
the process
Reporter: jng | Owner: pagameba
Type: defect | Status: new
Priority: medium | Milestone:
Component: Fusion | Version: 2.0.0
Severity: minor | Resolution:
Keywords: fusion | External_id:
Changes (by jbirch):
* milestone: 2.1 =>
Comment:
Doesn't look like this got addressed for 2.1. Removing the milestone.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/333#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
