[mapguide-trac] #1006: Web Layout not working
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 28 18:08:55 EDT 2009
 Reporter:  JackOfHearts  |         Owner:
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:
Component:  General       |       Version:  2.1.0
 Severity:  major         |    Resolution:
 Keywords:  web, layout   |   External_id:
Comment (by crispinatime):
 This "error" is usually because the wrong version of .net is assigned to
 the virtual directories.  In IIS look at the properties of the "mapguide"
 and "mapviewerajax" virtuals and on the asp.net tab ensure that .net 2.0
 is set.  Then do an IISreset or reboot for good measure.
 The new installer *should* be setting these properly but good to check!
  Crispin
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1006#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
