[mapguide-trac] #1142: Maestro: Adding layers to map enhancement
trac_mapguide at osgeo.org
Mon Nov 9 17:07:00 EST 2009
Reporter: jbirch | Owner: ksgeograf
Type: enhancement | Status: closed
Priority: low | Milestone: Maestro-2.0
Component: Maestro | Version:
Severity: minor | Resolution: fixed
Keywords: | External_id:
Changes (by ksgeograf):
* status: assigned => closed
* resolution: => fixed
Comment:
Fixed in r4336.
You can now select multiple items in both the "Open Resource" dialog, and
in the "add layers to map" dialog.
Please re-open if the "remember last location" should be added as well.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1142#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
