[mapguide-trac] #1113: Maestro: consider supporting TCP
connections
trac_mapguide at osgeo.org
Tue Nov 10 16:23:20 EST 2009
#1113: Maestro: consider supporting TCP connections
Reporter: jbirch | Owner: ksgeograf
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Resolution:
Keywords: | External_id:
Comment (by ksgeograf):
The problem with the native API is that it requires binaries for the
specific version, so you would have to know in advance what binaries to
use.
Secondly, the way the MapGuideDotNetApi.dll is tied to the binaries, means
that you would have to make an override in the app.config file to load the
correct dll.
Neither of those changes are trivial, and only apeals to the most hardcore
users.
You would also need a webconfig.ini file.
The only benefit I can think of is that it does not require the WebServer
to function.
Do you have specific use cases?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1113#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
