[mapguide-trac] #674: Additional RuntimeMap functions and overloaded members
MapGuide Open Source trac_mapguide at osgeo.org
Sun Nov 15 18:36:27 EST 2009
 Reporter:  MaksimS      |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  closed
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:  fixed
 Keywords:               |   External_id:
Changes (by ksgeograf):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Fixed in r4345.
 The ServerConnectionI now has the clipping method, but it is not used in
 the LocalNativeVersion, because the API is missing an overload of the
 function that takes that parameter.
 The runtime map now has methods that return the stream or a bitmap.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/674#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
