[mapguide-trac] #1155: Maestro: would be useful to pre-fill the
legend label with the same value as the layer name
trac_mapguide at osgeo.org
Tue Nov 17 19:27:15 EST 2009
#1155: Maestro: would be useful to pre-fill the legend label with the same value
as the layer name
Reporter: jbirch | Owner: ksgeograf
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
When adding layers to a MapDefinition, it would be useful if Maestro could
pre-fill the Legend Label field with the same value as the Name field.
This would allow the author to modify it if it is inappropriate, but would
reduce the amount of initial authoring work if the default name is
appropriate.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1155>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
