[mapguide-trac] #1156: MGRS Polar region grid/graticule lines
incorrect
trac_mapguide at osgeo.org
Fri Nov 20 13:01:50 EST 2009
#1156: MGRS Polar region grid/graticule lines incorrect
Reporter: NormOlsen | Owner: NormOlsen
Type: defect | Status: closed
Priority: high | Milestone:
Component: General | Version: 2.0.2
Severity: major | Resolution: fixed
Keywords: MGRS Grid Polar | External_id: 1273536
Changes (by NormOlsen):
* status: new => closed
* resolution: => fixed
Comment:
Corrected by a submission which produced revision 4351. The submission
was substantial, and included two new code modules:
CoordsysMgrsMajorRegion.h.
CoordSysMgrsMajorRegion.cpp
1> The generation of MGRS regions was originally accomplished by the 6x8
graticule generator. This was replaced by the two new objects referenced
above.
Thus, MGRS major region generation now accounts for the difference of Band
X
from other bands and also the rather strange stuff that goes on in the
vicinity
of Norway.
2> Logic was added to the MGRS Zone object generator so that the provided
frame
boundary is tested to see if it includes either pole. If so, the MGRS
Zone
object generator generates zones for the respective polar regions
regardless of
the latitudes of the bounding box.
3> The boundary of the the polar regions as sent off to the MGRS Zone
object was
changed from rectangular to a representation of a complete parallel of
latitude
in the frame coordinate system (usually a circle).
4> 100Km block designation code was added so that the 100Km grid in the
polar regions is properly labeled.
5> Problems in the clipper where the line being clipped passed exactly
through a
vertex in the clipping boundary were corrected.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1156#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
