[mapguide-trac] #1082: Existing basic web layout should not
ping server by default
trac_mapguide at osgeo.org
Wed Sep 2 02:49:25 EDT 2009
#1082: Existing basic web layout should not ping server by default
Reporter: christinebao | Owner: Chris Claydon
Type: defect | Status: new
Priority: medium | Milestone: 2.2
Component: AJAX Viewer | Version: 2.0.2
Severity: major | Resolution:
Keywords: | External_id: 1249172
Comment (by christinebao):
Tech diagnosis:
Basic web layout read from bool MgWebLayout::GetEnablePingServer() to know
whether or not should ping server. It works for basic web layout created
since schema change:[[BR]]
WebLayout-1.1.0.xsd[[BR]]
<xs:element name="WebLayout" type="WebLayoutType"/>
<xs:complexType name="WebLayoutType">
<xs:sequence>
<xs:element name="Title" type="xs:string"/>
<xs:element name="Map" type="MapType"/>
<xs:element name="EnablePingServer" type="xs:boolean" minOccurs="0"
<xs:element name="ToolBar" type="ToolBarType"/>
<xs:element name="InformationPane" type="InformationPaneType"/>
<xs:element name="ContextMenu" type="ContextMenuType"/>
<xs:element name="TaskPane" type="TaskPaneType"/>
<xs:element name="StatusBar" type="StatusBarType"/>
<xs:element name="ZoomControl" type="ZoomControlType"/>
<xs:element name="CommandSet" type="CommandSetType"/>
</xs:sequence>
</xs:complexType>
[[BR]]
The element <EnablePingServer> indicates whether or not the basic web
layout should ping server. [[BR]]
However, for the basic web layout created before, there is not such
<EnablePingServer> element. The default value should be set as false
instead of true, so the existing basic web layout can keep the same
behavior as before.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1082#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
