[mapguide-trac] #1085: ShowNorthArrow in Print Widget (Fusion Editor)
MapGuide Open Source trac_mapguide at osgeo.org
Mon Sep 7 11:16:43 EDT 2009
 Reporter:  pcardinal  |         Owner:  ksgeograf
     Type:  defect     |        Status:  assigned
 Priority:  low        |     Milestone:  Maestro-2.0
Component:  Maestro    |       Version:  2.0.2
 Severity:  trivial    |    Resolution:
 Keywords:             |   External_id:
Comment (by pcardinal):
 Replying to [comment:1 ksgeograf]:
 > You are correct, that is likely a copy-n-paste error I've made.
 Hi Kenneth,
 In Print.cs
 // ShowLegend
 this.ShowLegend.TabIndex = 24;
 this.ShowLegend.Text = "Hide invisible layers";
 // ShowTitle
 this.ShowTitle.TabIndex = 27;
 this.ShowTitle.Text = "Show Root Folder";
 // ShowPrintUI
 this.ShowPrintUI.TabIndex = 26;
 this.ShowPrintUI.Text = "Hide invisible layers";
 Same as previous in ShowNorthArrow
 Regards,
 Pierre
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1085#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
