[mapguide-trac] #1087: MgCooker: Option to specify alternative bounds
MapGuide Open Source trac_mapguide at osgeo.org
Mon Sep 7 15:17:03 EDT 2009
   Reporter:  ksgeograf    |       Owner:  ksgeograf
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 When calculating the tile set, sometimes the bounds set in the map does
 not correspond to the full extent.
 It is sometimes possible to pan outside the map bounds, if using
 OpenLayers or other viewer.
 If MgCooker had an option to specify an alternate bounds setting more or
 less tiles could be generated to better support other viewers.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1087>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
