[mapguide-trac] #1089: Plot to DWF (eplot) - plot wrong -> islands/holes filled
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 11 00:32:08 EDT 2009
   Reporter:  waltweltonlair   |       Owner:  waltweltonlair
       Type:  defect           |      Status:  new
   Priority:  high             |   Milestone:  2.2
  Component:  Mapping Service  |     Version:  2.1.0
   Severity:  major            |    Keywords:
External_id:  1244387          |
 Polygons containing holes are not handled properly in EPlots generated
 using 'Plot to DWF'.  If a polygon feature's contours have orientations
 that differ from that required by the DWF spec, then the polygon is not
 rendered correctly by the DWF Viewer.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1089>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
