[mapguide-trac] #1096: <coordinates> tag in generated KML does
not follow spec
trac_mapguide at osgeo.org
Thu Sep 17 18:40:50 EDT 2009
#1096: <coordinates> tag in generated KML does not follow spec
Reporter: jcarranz | Owner:
Type: defect | Status: closed
Priority: medium | Milestone: 2.2
Component: KML Service | Version: 2.1.0
Severity: minor | Resolution: fixed
Keywords: | External_id:
Changes (by tomfukushima):
* status: new => closed
* resolution: => fixed
* milestone: => 2.2
Comment:
r4232 for 2.2
Although this ticket is low priority I made the change because it is quite
simple and innocuous.
Removed the spaces from all of the coordinates generated from the KML
renderer.
Tested by viewing polygon, line and point data in Google Earth before the
change and then viewing it again after the change.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1096#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
