[mapguide-trac] #1104: Mapagent.fcgi SelectFeatures does not
support application/json
trac_mapguide at osgeo.org
Wed Sep 23 18:57:13 EDT 2009
#1104: Mapagent.fcgi SelectFeatures does not support application/json
Reporter: jcarranz | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: Map Agent | Version: 2.1.0
Severity: trivial | Keywords:
External_id: |
Using the mapagent.fcgi with OPERATION=SELECTFEATURES on sample Sheboygan
data, xml is returned (although the return content type of the response is
incorrect - not returned as text/xml)
Test url:
http://localhost:8080/mapguide/mapagent/mapagent.fcgi?OPERATION=SELECTFEATURES&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=Library%3A%2F%2FSamples%2FSheboygan%2FData%2FVotingDistricts.FeatureSource&CLASSNAME=SDF_2_Schema%3AVotingDistricts&PROPERTIES=&COMPUTED_ALIASES=&COMPUTED_PROPERTIES=&FILTER=&FORMAT=text/xml
But the equivalent call which is supposed to output JSON still produces
XML
http://localhost:8080/mapguide/mapagent/mapagent.fcgi?OPERATION=SELECTFEATURES&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=Library%3A%2F%2FSamples%2FSheboygan%2FData%2FVotingDistricts.FeatureSource&CLASSNAME=SDF_2_Schema%3AVotingDistricts&PROPERTIES=&COMPUTED_ALIASES=&COMPUTED_PROPERTIES=&FILTER=&FORMAT=application/json
Other mapagent operations that i've tested seem to behave correctly.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1104>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
