[mapguide-trac] #1109: MgLayerBase bypass its subclasses
trac_mapguide at osgeo.org
Sun Sep 27 02:44:03 EDT 2009
Reporter: christinebao | Owner: Christine Bao
Type: defect | Status: new
Priority: medium | Milestone:
Component: General | Version: 2.0.2
Severity: trivial | Keywords:
External_id: |
The inheritance hierarchy of MgLayerBase and its subclasses is:
| | MgLayerBase | |
| |SetLayerDefinition(resourceId, resourceService) | |
| |SetLayerResourceContent(resourceContent) | |
| |GetLayerInfoFromDefinition(resourceService) | |
| MapGuide --|-----------------------
| | MgLayer | | | AcMapLayer
| |GetLayerInfoFromDefinition(...)| |
MgLayerBase and MgLayer are in MapGuide, and AcMapLayer is in Map 3D.
Although MgLayerBase and MgLayer have
GetLayerInfoFromDefinition(resourceService), they are for different
purpose.
MgLayerBase::GetLayerInfoFromDefinition(resourceService) is to read layer
definition from resource service, and build up a runtime layer definition
model.
MgLayer::GetLayerInfoFromDefinition(resourceService) is to initialize
identity property of this layer.
What's the problem:
During Trevor's fixing of ticket:
http://trac.osgeo.org/mapguide/ticket/1002 (Batch Processing for Get
Identity Properties), a flag is added to MgLayer's constructor
"initIdProps" -- if initIdProps == true, MgLayer will initialize identity
properties by calling its GetLayerInfoFromDefinition(resourceService); if
initIdProps == false, MgLayer will ignore initialize identity property,
instead a batch process will do this.
MapGuide uses the second scenario (initIdProps==false) after Trevor's
fixing, a simple code snippet is:
Ptr<MgLayerBase> layer = new MgLayer(layerDefinition, resourceService,
false/*initIdProps*/, false/*initLayerDefinition*/);
layer->SetLayerDefinition(newLayerDefinition, newResourceService);
or
layer->SetLayerResourceContent(layerDefinitionContent);
//batch process identity properties
In function SetLayerDefinition(resourceId, resourceService) and
SetLayerResourceContent(resourceContent) a new layer definition model
should be set up to replace the previous one, so
MgLayerBase::GetLayerInfoFromDefinition(resourceService) should be used.
Thus it force used MgLayerBase to do this. Take
SetLayerResourceContent(resourceContent) for example:
//reset data members: m_definition, m_name etc
MgLayerBase::GetLayerInfoFromDefinition(resourceService);
//trigger events of OnLayerDefinitionChanged
It works for MapGuide and all test case passes. However a defect happens
in Map 3D. AcMapLayer overrides
GetLayerInfoFromDefinition(resourceService); and it should be used when
calling SetLayerDefinition(resourceId, resourceService). But it's bypass
and not get triggered.
How to fix:
Both the subclasses should trigger MgLayerBase's function to re-setup
layer definition model, while do the override of itself. In code aspect:
1. MgLayerBase::SetLayerDefinition(resourceId, resourceService) should
call GetLayerInfoFromDefinition(resourceService) without class name
prefix. If the subclass has override, it will be triggered.
2. Subclass should re-setup layer definition model, and for MgLayer it
should consider initIdProps before re-initialize identity properties.
Lessen from this case:
As GisPlatform is shared between MapGuide and Map 3D, more cases should be
considered when API changes.
Related RFC: http://trac.osgeo.org/mapguide/wiki/MapGuideRfc73.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1109>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
