[mapguide-trac] #1411: Make installer components buildable with VS express
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 3 04:58:46 EDT 2010
   Reporter:  jng        |       Owner:
       Type:  task       |      Status:  new
   Priority:  medium     |   Milestone:
  Component:  Installer  |     Version:
   Severity:  major      |    Keywords:
External_id:             |
 The current installer components are not buildable via VS express due to
 the following:
  * Installer.sln is a solution of Wix/C++ projects. VS express can't build
 heterogeneous solution files.
  * The apache custom action uses MFC, which is not included (and thus not
 buildable) in VC express.
  * VS express doesn't support bootstrapper packages AFAIK
 This ticket proposes the following be done to address this:
  * Split Installer.sln into separate wix and custom action solutions.
 Modify build.bat to build these solutions separately.
  * Rewrite the apache custom action library using a non-MFC approach
  * Ditch the existing bootstrapper and tweak the NSIS installer to include
 logic that determines whether to launch a vc_redist installation before
 the main msi installer is executed. In effect the NSIS installer *becomes*
 the bootstrapper.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1411>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
