[mapguide-trac] #1417: Maestro: version on OSGeo Live DVD does not allow theming by column
MapGuide Open Source trac_mapguide at osgeo.org
Thu Aug 5 23:50:19 EDT 2010
   Reporter:  jbirch   |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 When attempting to select a column to theme by, get an error message like:
  Error: An exception occurred in FDO component.
         FDO class '-x31-0m_populated_places_simple' not found in schema.
 The schema/class is actually "Default:10m_populated_places_simple"
 This is odd because all of the other column-related calls such as the
 lookup in the expression editor don't seem to have a problem with the
 class name.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1417>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
