[mapguide-trac] #1422: Add enhanced stylization support for
UnitsControl
trac_mapguide at osgeo.org
Wed Aug 11 18:30:42 EDT 2010
#1422: Add enhanced stylization support for UnitsControl
Reporter: waltweltonlair | Owner: waltweltonlair
Type: task | Status: new
Priority: medium | Milestone: 2.3
Component: General | Version: 2.1.0
Severity: minor | Keywords: stylization
External_id: |
The !UnitsControl setting is part of the !LineUsage element, and it
controls whether the Repeat / !StartOffset / !EndOffset values are
interpreted as absolute or parametric values. In the parametric case the
values should be specified in the range [0, 1], and they are scaled by the
length of each feature contour on which the line style is applied. So for
example, you could specify a line style that always draws three symbols on
each polyline feature - one at the start, one at the center, and one at
the end - by specifying Repeat / !StartOffset / !EndOffset = {0.5, 0, 0}.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1422>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
