[mapguide-trac] #1554: Assign one new user the Map Author role
caused deletion of Administrator role
trac_mapguide at osgeo.org
Thu Dec 9 12:00:23 EST 2010
#1554: Assign one new user the Map Author role caused deletion of Administrator
role
Reporter: brucedechant | Owner: brucedechant
Type: defect | Status: closed
Priority: high | Milestone: 2.3
Component: Resource Service | Version: 2.2.0
Severity: critical | Resolution: fixed
Keywords: | External_id:
Description changed by brucedechant:
Old description:
> When a new usr is assigned the Map Author role it causes the deletion of
> the Administrator role. This in turn causes the Administrator to no
> longer have access to the site.
> Steps to reproduce this defect:
> 1. Launch MG site administrator.
> 2. Create a new user.
> 3. Assign the user the Map Author role.
> Results:
> Error occurs - Administrator role cannot access the Site anymore.
> Expected results:
> After assigning the role, each user still works as usual.
New description:
the Administrator role. This in turn causes the Administrator to no longer
Results:
Expected results:
Note: This issue was discovered while testing the upgrade DBXML for 2.3
and does not exist prior.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1554#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
