[mapguide-trac] #1567: Tiled image is still PNG file although ImageFormat set to GIF
MapGuide Open Source trac_mapguide at osgeo.org
Thu Dec 9 17:48:10 EST 2010
   Reporter:  brucedechant       |       Owner:  brucedechant
       Type:  defect             |      Status:  new
   Priority:  low                |   Milestone:  2.3
  Component:  Rendering Service  |     Version:  2.2.0
   Severity:  trivial            |    Keywords:
External_id:                     |
Changes (by brucedechant):
  * owner:  => brucedechant
Old description:
> If you change the ImageFormat property inside the serverconfig.ini file
> to GIF it still generates PNG files.
New description:
 If you change the !ImageFormat property inside the serverconfig.ini file
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1567#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
