[mapguide-trac] #1562: Web Layout Editor loose ends
trac_mapguide at osgeo.org
Fri Dec 10 08:33:05 EST 2010
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-3.0
Component: Maestro | Version: 2.1.0
Severity: trivial | Keywords:
External_id: |
Description changed by jng:
Old description:
> The Web Layout editor in Maestro 3.0 has some loose ends that require
> fixing up:
> * Adding new commands will correctly add the corresponding entries in
> the menus toolbar, but the labels are blank.
> * The button in the Invoke URL command editor that should launch a layer
> selector does not work.
> * Icons should be shown beside each command, or at least show icons for
> the custom commands (Invoke URL, Search, Invoke Script)
New description:
fixing up:
* Adding new commands will correctly add the corresponding entries in the
* Moving menu items up and down should retain selection
* Menu items should be able to be relocated by dragging and dropping
* Though the spec may indicate otherwise, flyout menus only nest one
level deep. Ensure this is enforced.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1562#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
