[mapguide-trac] #1072: PHP CLI errors out under Windows 2008 /
Vista when MapGuide extension loaded
trac_mapguide at osgeo.org
Fri Dec 10 15:40:47 EST 2010
#1072: PHP CLI errors out under Windows 2008 / Vista when MapGuide extension
loaded
Reporter: jbirch | Owner: brucedechant
Type: defect | Status: closed
Priority: medium | Milestone:
Component: Web API | Version: 2.1.0
Severity: minor | Resolution: wontfix
Keywords: php, cli | External_id:
Changes (by brucedechant):
* status: assigned => closed
* resolution: => wontfix
Comment:
This is a known PHP issue.
PHP defect 38111 : PHP crashes IIS worker process and application pool
From the defect notes:
Closing this bug as well as no useful information has been provided and
the ISAPI is going to be deprecated anyway. Use FastCGI istead with
IIS5/6/7.
Moving to FastCGI resolves this.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1072#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
