[mapguide-trac] #1579: Ajax: Type string for Transparency results
in Buffer fails
trac_mapguide at osgeo.org
Sun Dec 26 21:33:00 EST 2010
#1579: Ajax: Type string for Transparency results in Buffer fails
Reporter: hubu | Owner: hubu
Type: defect | Status: new
Priority: low | Milestone: 2.3
Component: AJAX Viewer | Version: 2.2.0
Severity: minor | Keywords:
External_id: 1366711 |
1. Open a BWL, select a feature, and active the "Buffer" Panel.
2. Type string "test" in Transparency text box field
3. Click "Done" button
Result:
An Aspx error is encountered, complains that the can't convert the string
to double
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1579>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
