[mapguide-trac] #1267: MgLayerBase::SetLayerDefinition should not
change layer name
trac_mapguide at osgeo.org
Tue Feb 9 12:51:08 EST 2010
#1267: MgLayerBase::SetLayerDefinition should not change layer name
Reporter: tomfukushima | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Web API | Version: 2.1.0
Severity: trivial | Keywords:
External_id: 1289652.01 |
When working with a !MgLayerBase object, by default the layer gets a name
derived from the resource ID of the layer definition. This is good
because a name other than "" is good and resource ID is as good as
anything for a default. The app developer can then use !SetName to change
the name to something more to their liking. However, when
MgLayerBase::!SetLayerDefinition is called, the layer name will be reset
to the resource ID of the layer definition. We need to remove this side
effect for the cases when the developer has actually set the Name to
something other than the default.
Will need to check all code where !SetLayerDefinition is used to make sure
that this functionality is not relied upon.
If this is fixed it will cause a change in behavior to the API so a note
must be added to the release notes.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1267>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
