[mapguide-trac] #1273: Update to support GetProcessMemoryInfo() on all supported Windows platforms
MapGuide Open Source trac_mapguide at osgeo.org
Tue Feb 16 16:47:22 EST 2010
   Reporter:  brucedechant  |       Owner:  brucedechant
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  2.2
  Component:  Server        |     Version:  2.1.0
   Severity:  minor         |    Keywords:
External_id:                |
 Microsoft made a change to the !GetProcessMemoryInfo API which is used by
 the MapGuide !GetSiteInfo HTTP API.
 The following is from MSDN:
 http://msdn.microsoft.com/en-us/library/ms683219(VS.85).aspx
 Starting with Windows 7 and Windows Server 2008 R2, Psapi.h establishes
 version numbers for the PSAPI functions. The PSAPI version number affects
 the name used to call the function and the library that a program must
 load.
 If PSAPI_VERSION is 2 or greater, this function is defined as
 K32GetProcessMemoryInfo in Psapi.h and exported in Kernel32.lib and
 Kernel32.dll. If PSAPI_VERSION is 1, this function is defined as
 !GetProcessMemoryInfo in Psapi.h and exported in Psapi.lib and Psapi.dll
 as a wrapper that calls K32GetProcessMemoryInfo.
 Programs that must run on earlier versions of Windows as well as Windows 7
 and later versions should always call this function as
 !GetProcessMemoryInfo. To ensure correct resolution of symbols, add
 Psapi.lib to the TARGETLIBS macro and compile the program with
 –DPSAPI_VERSION=1. To use run-time dynamic linking, load Psapi.dll.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1273>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
