[mapguide-trac] #1175: Failed to set map name using MgMap.Open
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 4 11:28:28 EST 2010
 Reporter:  liuar    |         Owner:
     Type:  defect   |        Status:  closed
 Priority:  low      |     Milestone:  2.2
Component:  General  |       Version:  2.0.2
 Severity:  trivial  |    Resolution:  fixed
 Keywords:           |   External_id:  1289006
Changes (by brucedechant):
  * milestone:  => 2.2
Old description:
> a.Assume we have a MapDefinition called
> “Library://Test/Default.MapDefinition”;[[BR]]
> b.We create the map using the following code:[[BR]]
>     MgMap map = new MgMap();
>     map.Create(resourceService, new
> MgResourceIdentifier(“Library://Test/Default.MapDefinition”),
> “Default1234”);
>     map.Save();
> c.In other code, we want to use this map, so we use this code:[[BR]]
>     map.Open(resourceService, “Default1234”);
> d.Now the Name property for map in step c) is supposed to be
> “Default1234”. However, you’ll find it’s still “Default”, the name of map
> definition, not the name of map.[[BR]]
> If you open the code of
> “\\trunk\MgDev\Common\MapGuideCommon\MapLayer\Map.cpp”, you’ll find the
> line 504 and 505 is like this:[[BR]]
>     m_name = mapName;
>     MgResource::Open(m_resourceService, resId);
> However, MgResource::Open will use the name of map definition, not the
> name of map to replace the value of m_name.[[BR]]
> So we should put “m_name = mapName;” behind “MgResource::Open”.
New description:
 * Assume we have a !MapDefinition called
  * We create the map using the following code:
 “Default1234”);
     map.Save();
  * In other code, we want to use this map, so we use this code:
  * Now the Name property for map in step c) is supposed to be
 “\\trunk\!MgDev\Common\!MapGuideCommon\!MapLayer\Map.cpp”, you’ll find the
     m_name = mapName;
 However, MgResource::Open() will use the name of map definition, not the
 So we should put “m_name = mapName;” behind “MgResource::Open()”.
Comment:
 Fixed in trunk. Submission r4461
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1175#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
