[mapguide-trac] #940: Scale dependent layers appearing as the
user zooms in added to bottom of the legend
trac_mapguide at osgeo.org
Thu Jan 7 21:48:58 EST 2010
#940: Scale dependent layers appearing as the user zooms in added to bottom of
the legend
Reporter: cuic | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: General | Version: 2.1.0
Severity: major | Resolution:
Keywords: | External_id: 1194652
Comment (by liuar):
Hi Mike,[[BR]]
I think this defect still can be reproduced by following steps[[BR]]
1. You can simply add two layers(layer1 and layer2) in a map and update
the map's draw order to make layer1 display over layer2. [[BR]]
2. Update the scale range settings for each layer. Layer1(0-1500) and
layer2(0-Infinity)[[BR]]
3. Adjust the initial view of map to make sure the initial scale is larger
than 1500.[[BR]]
4. Preview the weblayout. Only layer2 is displayed in map and legend[[BR]]
5. Zoom in to 1:1000 and I could see layer1 displayed over layer2 in map,
but in the legend, the layer1 is below layer2 which is inconsistent with
draw order.[[BR]]
Thanks,[[BR]]
Arthur
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/940#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
