[mapguide-trac] #1231: Maestro: consider adding way to copy/paste resource between windows (using clipboard?)
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jan 8 16:16:57 EST 2010
clipboard?)
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by jbirch):
 My work flow right now is either to create packages or, when I just have
 specific resources within a folder I need to transfer, to open both
 resources as XML and copy/paste between them.  Both of these are multi-
 step operations, so a mini package-transfer function would be quite useful
 when moving resources between two identical servers (test/prod).
 For interest, my current process is to dump both repositories out as
 packages, and compare the text contents of the unzipped packages in Beyond
 Compare, then go in to Maestro and update the modified resources from test
 to prod where the differences are due to changes rather than intentional
 differences between test/prod.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1231#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
