[mapguide-trac] #1221: Maestro: layer order enhancements
trac_mapguide at osgeo.org
Fri Jan 8 16:33:03 EST 2010
Reporter: jbirch | Owner: ksgeograf
Type: enhancement | Status: assigned
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Resolution:
Keywords: | External_id:
Comment (by jbirch):
Hmm.
For #1 the behaviour doesn't seem to be consistent. With multiple
disjoint items selected, sometimes only the top two move (when getting
near the top of a large list), sometimes all four. The "Move to Top"
function works well.
For #2 ah well. Was a nice thought :)
For #3 what I meant was for the last item to insert itself into the layer
order relative to the position of the last item in the group it's inserted
into. For instance, if the last item in the group is at position 9 in a
map containing 30 layers, that the newly added layer be inserted at
position 10. Currently, it shows up at the bottom of the group, but is
inserted into the layer order list at position 31.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1221#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
