[mapguide-trac] #1238: Problem handling NULL values with SDF in 2.1 final
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jan 10 08:36:41 EST 2010
 Reporter:  ksgeograf  |         Owner:
     Type:  defect     |        Status:  new
 Priority:  low        |     Milestone:
Component:  Web API    |       Version:  2.1.0
 Severity:  minor      |    Resolution:
 Keywords:             |   External_id:
Comment (by ksgeograf):
 Hmm... Annoying... Trac has removed my linefeeds... Here it is with forced
 linefeeds:
 If a datasource has NULL values, it is impossible to read data from the
 Http interface.
 See SDF file attached to ticket #1228.
 Using the test page:
 http://localhost/mapguide/mapagent/selectfeaturesform.html
 Attempting to read features gives: "Value for LUMINAIRETYPE property is
 null"
 Attempting various ways to overcome this with a filter always returns an
 empty result set: [[BR]]
 LUMINAIRETYPE <> NULL[[BR]]
 LUMINAIRETYPE != NULL[[BR]]
 NOT LUMINAIRETYPE = NULL[[BR]]
 It seems as if any filter returns an empty result set: [[BR]]
 LUMINAIRETYPE LIKE '*' [[BR]]
 LUMINAIRETYPE = NULL [[BR]]
 LUMINAIRETYPE > 5 [[BR]]
 The last one should give an error as LUMINAIRETYPE is a string column.
 Perhaps the data is somehow broken, but it is possible to view the data by
 creating a FeatureSource? and using the "Preview" function in
 Maestro/Studio.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1238#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
