[mapguide-trac] #1232: Maestro: does not properly escape GT symbol in map metadata
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jan 10 10:02:52 EST 2010
 Reporter:  jbirch   |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  medium   |     Milestone:  Maestro-2.1
Component:  Maestro  |       Version:
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:
Changes (by ksgeograf):
  * milestone:  Maestro-2.0 => Maestro-2.1
Comment:
 Ok, I have done some testing, and you are correct; it does not escape
 those characters.
 But for some reason the Xml with the unescaped characters is accepted by
 any program that I can test with, eg.: MapGuide itself, Firefox and IE.
 This suggests that the escape is done correctly, even if it is different
 than I would expect.
 http://www.w3.org/TR/REC-xml/#syntax
 Describes that < MUST be escaped, where > MUST be escaped only in CDATA
 fragements.
 I don't think I can fix Maestro so the output has those correctly escaped
 without writing a custom serializer.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1232#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
