[mapguide-trac] #1388: MgMap.Create causes crash of 64 bit Web
Extensions on Windows
trac_mapguide at osgeo.org
Fri Jul 2 11:58:53 EDT 2010
#1388: MgMap.Create causes crash of 64 bit Web Extensions on Windows
Reporter: trevorwekel | Owner: trevorwekel
Type: defect | Status: new
Priority: high | Milestone: 2.2
Component: Web API | Version: 2.2.0
Severity: blocker | Keywords: web extensions 64 bit crash
External_id: |
Comment(by trevorwekel):
After some debugging, it was determined that IIS was not picking up the
MENTOR_DICTIONARY_PATH environment variable without reboot. Since the
coordinate system library was not initialized, the call to !MgMap.Create
would fail.
One fix is to restart IIS after the installation. Jackie also found some
information on IIS environment variable overrides which may be applicable.
http://www.teachout.com/Blog/tabid/165/EntryId/246/Windows-Environment-
Variables-Overrides-for-IIS6.aspx
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1388#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
