[mapguide-trac] #1397: When the length of TaskPane url is less than
8, there will be a exception
trac_mapguide at osgeo.org
Fri Jul 9 06:09:36 EDT 2010
#1397: When the length of TaskPane url is less than 8, there will be a exception
Reporter: hubu | Owner: hubu
Type: defect | Status: new
Priority: medium | Milestone:
Component: General | Version: 2.1.0
Severity: trivial | Keywords:
External_id: |
1. create a simple html, and named it as 1.html(note: the name length
should less than 8). Or you can use the attached 1.html file as your test
page.
2. Put the 1.html file to the mapguide/mapgudieajaxviwer/ folder
3. In the MG Studio, open a basic weblayout. In the setting panel, input
the "1.html" as the value of "URL for home task displayed in the Task
Pane"
4. Preview this weblayout in the browser.
Result:
An exception thrown:
Index and length must refer to a location within the string. Parameter
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1397>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
