[mapguide-trac] #1278: Apache crashes under load
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jul 12 10:56:42 EDT 2010
   Reporter:  hubu     |       Owner:  hubu
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:  2.2
  Component:  Web API  |     Version:  2.1.0
   Severity:  blocker  |    Keywords:  Apache upgrading
External_id:  1302967  |
Changes (by brucedechant):
 * cc: brucedechant (added)
Old description:
> While running the Grinder test scripts against an Apache/PHP web tier
> configuration the Apache server can crash randomly. This has been
> observed several times while testing.
> The current release of Apache included with MGE2011 is 2.2.11 which has a
> known issue PR 47672.
> Apache PR 47672: fix seg fault under load due to pool concurrency problem
> This Apache defect has been corrected in release 2.2.14.
> We need to upgrade to release 2.2.14.
New description:
 configuration the Apache server can crash randomly. This has been observed
 The current release of Apache included with MGOS 2.2 is 2.2.11 which has a
 We need to upgrade to release 2.2.14 or later.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1278#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
