[mapguide-trac] #1370: Can't login using 2.1 preview
trac_mapguide at osgeo.org
Tue Jun 8 22:07:52 EDT 2010
Reporter: andrewd | Owner: jng
Type: defect | Status: assigned
Priority: high | Milestone: Maestro-2.1
Component: Maestro | Version: 2.1.0
Severity: major | Resolution:
Keywords: | External_id:
Comment (by jng):
Here's a simple test you can do:
Go to your mapagent test pages:
http://localhost:8008/mapguide/mapagent/index.html (Apache w/ default
config)
http://localhost/mapguide/mapagent/index.html (IIS w/ default config)
Go to '''Miscellaneous API''' - '''Other'''
Choose the '''CreateSession''' operation
Hit '''Submit''', use your default MG Administrator login.
If it doesn't spit out a long string of text (your session id), then it
must be some configuration issue and explains why Maestro can't log in.
If it does however, then it's a legit problem on the Maestro side.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1370#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
