[mapguide-trac] #1378: Cannot connect to SQL Server 2008 - 2.2 Beta 1
trac_mapguide at osgeo.org
Tue Jun 15 00:35:03 EDT 2010
Reporter: tybion | Owner:
Type: defect | Status: new
Priority: low | Milestone: 2.2
Component: Mapping Service | Version: 2.2.0
Severity: major | Keywords:
External_id: |
I create a SQL Server 2008 data connection in Maestro.
When I click the 'Test Connection' button I get the following error ..
The remote server returned an error: (559) MgConnectionFailedException.:
Problem:\nCannot establish connection to the MapGuide Server.\n\nPossible
Causes:\n-Your session has been idle for too long;\n-MapGuide Server is no
longer responding;\n-Internet connection problems.\n\nSolution:\nRestart
your application / session, restart the MapGuide Server service, or
contact with the server administrator.
MapGuide is using FDO 3.5
When I install FDO ToolBox 0.9.3.1063 (that also uses FDO 3.5), it works
fine - opens tables, identifies primary keys and geometry fields, and
queries on the tables also work fine.
Even if I change the configuration of MapGuide server to use the same FDO
folder as FDO ToolBox, it still reports the same error.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1378>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
