[mapguide-trac] #1380: Mapguide 2.2 beta on Linux fails to setup
locale from system
trac_mapguide at osgeo.org
Wed Jun 16 13:05:11 EDT 2010
#1380: Mapguide 2.2 beta on Linux fails to setup locale from system
Reporter: gabrimonfa | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version: 2.2.0
Severity: trivial | Keywords:
External_id: |
'''SO''': Centos 5.5
'''system locale''': en-US.UTF-8
'''locale from serverconfig.ini''': empty (from comment should default to
system locale)
provider: OGRProvider with libgdal rebuilt with Postgresql support.
viewer: plain Ajax
'''PostgreSQL locale''': UTF-8
I have a layer which stylization involves a rule that check if a field is
equals to a string containing a 'à'
Obtained results:
- that rule fails
- every time that the rule is evaluated one apache thread dies with
this message in the error_log:
terminate called after throwing an instance of
'MgInvalidArgumentException'
[notice] child pid 32615 exit signal Aborted (6)
(no messages on server Error.log even if loglevel is 3 on all
services, and also this is not so good)
- Changing the rule to plain 'a' does not solve the error, thus the
problem is in fetching the data from the db
- Changing the rule to plain 'a' and changing the row in the db does
solve the error (layer is correctly stylized and no more messages in
the error_log)
Reverting back to 'à' both in the db and in the rules and setting
"locale = en-US.UTF-8" in serverconfig.ini does solve the problem.
Thus I suppose that mapguide is using an incorrect locale (maybe
ISO8859-1 instead of UTF-8) and complains about finding invalid
characters.
This is a regression, since with Mapguide 2.1 (compiled on Debian) and the
same data all works correctly.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1380>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
