[mapguide-trac] #1378: Cannot connect to SQL Server 2008 - 2.2
Beta 1
trac_mapguide at osgeo.org
Wed Jun 16 15:29:53 EDT 2010
#1378: Cannot connect to SQL Server 2008 - 2.2 Beta 1
Reporter: tybion | Owner:
Type: defect | Status: new
Priority: low | Milestone: 2.2
Component: Mapping Service | Version: 2.2.0
Severity: major | Keywords:
External_id: |
Comment(by tomfukushima):
Perhaps the problem is because the SQL Server is running multiple
instances. Is there a default instance (i.e., Service = maittestsql)
there that you can try connecting to? And if so what happens when you try
connecting to that? Also try putting two backslashes between the machine
and sever name (i.e., maittestsql\\testsql2008) and see if that makes any
difference.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1378#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
