[mapguide-trac] #1338: Stray linework being drawn
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 3 15:43:10 EDT 2010
   Reporter:  jrizzo   |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  2.2
  Component:  General  |     Version:  2.2.0
   Severity:  trivial  |    Keywords:
External_id:           |
 MapGuide seems to be displaying stray linework when rendering certain DWF
 files.  To reproduce the problem, load the attached dwf into MapGuide and
 create a layer referencing the sheet "Elmwood Park - RDC1 4th Floor".
 Examine the layer as it is rendered by mapguide.  The drawing is a
 building floor plan - look in the vicinity of section D-1 of the drawing.
 There is a curved feature being drawn, passing through the label of office
 "4-105".  If you examine this sheet in Autodesk's Design Review
 application, that curved feature does not exist in the file.  This is not
 a new issue - I have observed this behavior in every version since
 MapGuide 1.0.  I have also seen this with other DWF files - this is only
 one example.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1338>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
